Highlighted
syefemsy
Hi,
I'm not sure if my galaxy S8plus has the problem or the cable or the pc or the car.
My car does not recognize my phone while cable is connected.
Then after a few days, my pc does not recognize my phone.
Then just yesterday my phone does not want to charge with the original cable.
I've used 2 original cables already.
I'm confused.
Help!
Thanks.
8 Comments
Highlighted
Tallman
According to your troubleshoot information, sounds like the USB-C port is malfunction. You may need to take it to Samsung Experience Store or Samsung authorised service center for repairing.
Highlighted
syefemsy
You may be right. I'm charging wireless now.
Highlighted
Hi @syefemsy,
As @Tallman rightly pointed out, it seems USB-C port has malfunctioned and your phone need to be repaired.  You can let us know if you need help with (in finding) Samsung authorized service center.
Cheers,
Kinsley
Highlighted
syefemsy
hi Kinsley, if that's the case, I'm at the east side of Toronto.
Highlighted
Hi syefemsy,
Please find the below Samsung authorized service centers details.
1.  Mobile Klinik - Dundas
Address: 10 Dundas Street East, M5B 2G9
Operating Hours Mon- Fri : 8:30AM to 8:30 PM ; SAT : 10:00 AM to 6:00 PM ; SUN CLOSED
Phone Number- 416-350-3777
Email Address: dundassquare@mobileklinik.ca
2.  Mobile Klinik - Queen
Address: 65 Queen Street West, Unit 81, M5H 2M5
Operating Hours Mon- Fri : 8:00AM to 6:00 PM ; SAT-SUN CLOSED
Phone Number: 647-343-4301
Email Address: 65queen@mobileklinik.ca
Cheers,
Kinsley
Highlighted
Ray2
Cables are the cheapest fix - I would try a new one first as is the most likely to be the  problem but port is also possible problem but get a price first and decide weather it is worth putting that kind of money in a S8 or just buy new phone
Highlighted
syefemsy
Hi Ray2, I have 2 original cables, same story. and yes I'll check the price first.
Highlighted
syefemsy
thank you for help guys!
