Cry for Help
(Topic created on: 02-07-2020 07:33 AM)
Canax1
I Need A New Phone 😭😭😭😭😭
5 Comments
Luqmanakim
What are your criteria?
Budget and needs from the phone?
Canax1
I Don't mind any as long as it's an android 9 or 10. I've been a using my j7prime and now the phone drains fast. I just need to change it 😭😭
Luqmanakim
What's the price range you're looking at?
 I suppose right now you can look at the S10 or the Note 9 which has drop down in price.
If not the new S10 Lite and Note 10 Lite offers flagship performance, great camera and latest android 10.
If cheaper, you can opt for the new A71 which lokks and feels awesome for its price (A51 also good).
If you go other brands, I suggest either Oneplus or Nokia as they have one of the fastest software updates history.
mFarooq
Am also using j7 Prime but i don't have any issue with it
Canax1
okay
