RickC
08-01-2016 12:29 PM in
Auto rotate not working and also lost the use of GPS in maps. All this happened when visiting another province and connected to free WiFi in a campground. Did everything possible to try and figure this problem out except losing everything to a factory reset, or is this due to all these updates and changes to apps ????
4 Comments
Nikkii1990
08-01-2016 09:16 PM in
I've had no problem since the update.. that's werid id call Samsung.
murph13
08-08-2016 04:52 AM in
if you pull down the menu on the home screen there is a button that says portrait push that button and it should says rotation after pressing it then your screen auto rotate
Nike0169
08-10-2016 08:59 PM in
if you have to factory reset try smart switch! it's the best way! DO NOT use samsung account backup! I just lost everything today! Wishing you lots of luck!!
brianr1
09-04-2016 10:06 PM in
my phone stopped rotating the screen. reboots, factory reset did not work either
