benaust
03-20-2020 01:00 PM in
Galaxy SMy s8 was very good with Google maps, but recently it is loosing the GPS signal. I have to close the map and open again. Some times I have to do this several times.
Thanks for any help.
4 Comments
keagan
03-20-2020 01:23 PM in
Galaxy SHey @ benaust,
Please check if the "Google Location Accuracy is ON".
You can check by following the below path.
Settings >> Location >> Google Location Accuracy -> Toggled on
I hope this information helps you.
makeanimationss mooth
03-20-2020 03:21 PM in
this also happens to me on S9
sully
03-21-2020 12:33 AM in
Are you on power save mode? If so, you may loose gps when display is turned off.
KPvan
03-22-2020 10:14 PM in
This is happening to me to S8.. Was reading similar issues on s20 and Samsung rolling out fix.. Hope same fix comes to s8 think gps issues started with Jan security patch
