S10 Battery Problem
(Topic created on: 11-29-2019 12:31 PM)
ivanpings
Hi, I'm not sure whether its the update but I've been experiencing a less than 4hr battery life instead of 5 hrs before. Is this a software problem or is my battery depleting already? Had the phone since March 2019.
7 Comments
ivanpings
SOT yes
uzairm87
lol my note 10 plus still gets 6.5 hrs but feels less
Cassidy
Did you Boot into Recovery and Wipe Cache after you applied the OTA?
If you didn't - do it & then see how the battery life is 🐧
ivanpings
i just did the wipe cache now i'll see if it makes a difference. anyways, thank you!
Geico
Accubattery is also a great app.
snooksnake
my s10 gets 12 to 14 hrs battery life
