oreo s7 edge
(Topic created on: 06-14-2018 05:07 PM)
bhawan
just updated my s7 edge to oreo. how do i use split screen? youtube/facebook google duo/ fb etc
5 Comments
Alex3748
hold down the app switch button (left side of the home button) with in a app
bhawan
sorry i meant to say picture in picture feature
A11
@ bhawan when you're watching YouTube drag the the screen from corner and the YouTube app will minimize and will be floating and you can open any other I app. I just tried it since you asked
bhawan
@A1 thanks
Moderator_
Hey @A1, thanks a lot for your accurate answer!
- Wonchul
