Gears s3 Frontier battery drain..
(Topic created on: 05-29-2019 08:21 AM)
fuzzuy
Beginner Level 3
Wearables
Hi,
I have Gears s3 forntier and offcourse it is out of warranty now as i was the first one who got that once there were out back in 2016 fall.
My problem is it died sudden even it is showing above 50% or more yesterday i used it on battery saving mode and it barely last up to 7 hours and than it died.
I understand that battries could fail here, any one know how ling typically it their battries last from the start.
And yes i did hard reset twice on it no use same situation.
Thank you in advance.
2 Comments
carr0498
Wearables
sounds like the battery is failing. not a lot you can do without bringing it in to a service center to be examined and maybe have them replace the battery. ensure you go to an authorized service center so they can restore the IP68 water and dust resistance of the device
fuzzuy
Beginner Level 3
Wearables
ok thanks
