Highlighted
Beginner Level 4
My samsung galaxy earbud plus left side is not or working or connected i just bought it 3 mos ago can somebody help to fix this issue
3 Comments
Highlighted
You can try to reset your buds using the Galaxy Wear App. Otherwise, that could be a hardware issue.
Highlighted
1.Put your Galaxy Buds inside the case.
2.Then unpair it from Bluetooth.
3.Reset it through the Galaxy Wearable App.
Highlighted
Beginner Level 4
but it dosent have reset on the galaxy wear apps
