Battery drain issues resolved
(Topic created on: 03-15-2024 03:37 PM)
DrewSkillz
Hey everyone,
For those who are experiencing battery drain problems on A53 or any A series after software updates, first thing to do is reset(clean data) every app and restart your device and check if that solved the battery issue. Of course, you can also do clear cache in recovery but the main problem you will face is the apps. Personaly, i do this and it helps very much.
3 REPLIES 3
I'll recommend recharging the phone and shutting it down completely, for battery calibration
Helenna
Hi DrewSkillz, we appreciate you for taking your time and sharing this information with our Samsung members community.
It will be really helpful for others who are facing the same issue.
Thank you.
Footy07
Thanks i have a53 too
