Edge lighting / Brief pop-up settings / LED notification?
(Topic created on: 09-04-2021 11:40 PM)
jumpingjacks
I don't understand how Edge lighting works on my A32 5g...  if I get a missed call I don't see any pop-up Edge Lighting. Same with SMS messages or email.
In fact the Brief pop-up settings doesn't have the edges at all.. only some animation on top or a bit on the sides.. really not sure why.
Then on top of that I don't see an option that says "Show even when screen is off" as i've seen in YT videos.
And how can I get the LED light under the Front Camera to act as a notification light?
Is it because i have running the One UI 3.1?? and they messed up the functions??
2 Comments
Valeriya
Hi jumpingjacks, Could you check if you have this option on your device for the edge lighting feature on the following path, Settings > Notifications > Brief pop-up settings.
jumpingjacks
Yes it's there, but there's no edge light option
