overheating and battery drain
(Topic created on: 11-09-2024 11:48 PM)
jipiyoon
anyone experiencing overheating and battery frain after updating the system from currernt patch this november?
4 REPLIES 4
mkmkmkmk
I feel battery draining a bit fast on my s23 fe since update and so does my s21 ultra, drops down to about 60% then it runs like normal
mkmkmkmk
Does your battery drain while not doing anything? I unplug my phone when fully charge and leave it at home while I'm out about come back at least 4 hours and it drains about 8-10% even with power saving on
jipiyoon
yes, it it is really hot even doin nothing
Mogay
usually a simple restart can solve the problem, and look up device care to look up which app running in the background for no reason (except google play service because this app always run in the background)
