09-08-2022 02:13 AM in
Galaxy J- Mark as New
09-08-2022 02:20 AM in
Galaxy JHello nintendohelp,
Thank you for reaching out to us. Don't worry, we are here to help.
Following are the guide you have to take in order to change the settings.
Settings > Apps > Tap the 3 dots in the top right > Show System Apps > System UI (green P thumbnail) > Notifications > Tap on 'Battery' > Notification Style (choose Sound or Sound and Pop-Up) > Sound (Select an option from the list)
Hope this content is helpful and your problem gets solved.
If the issue persists, you may contact our Samsung online support channels below.
09-08-2022 02:31 AM in
Galaxy J
