Hazizi6788
Galaxy Note
Good day,
Anyone can share any tips to get more battery saving due to my phone currently the battery drain so fast and feel hot at the screen. I only get around 5hour for SOT by using mobile data only. No gaming, off auto sync and off location and operate with 60hz only.
Thanks
8 Comments
ChowJianYu
Galaxy Note
Reduce app running on background
Hazizi6788
Galaxy Note
Adjust at device care?tq sir
ChowJianYu
Galaxy Note
I use memory guardian, I guess you can do it too by optimizing your phone at device care
Hazizi6788
Galaxy Note
Its that 3rd party apps? Memory guardian? I will try it ..tq sir
ChowJianYu
Galaxy Note
It is actually a Good Lock app but Malaysia don't have Good Lock so I use Fine Lock as a launcher for apps in Good Lock
ChowJianYu
Galaxy Note
You can get Fine Lock on Google Play and download Memory Guardian from trusted APK sideload website like APKMIRROR
Hazizi6788
Galaxy Note
Okay..i already find it for memory guardian that will come with galaxy labs..and this apps will get for galaxy s21 series..unfortunately for note 20.. i have bad feeling to download apps if the apps cant download from galaxy store or play store..😅😅😅
KJ26
Galaxy Note
Don't worry, it's totally safe. I'm using a Note 20 Ultra and I've been side-loading Good Lock (or it's replacement Fine Lock) ever since my S7 Edge days and nothing bad has happened to any of my phones. A word or caution, only Side-Load from sites that you have total confidence in, I only ever sideload from APKMIRROR and Sam Mobile.
