battery drain issue
(Topic created on: 02-25-2021 10:44 AM)
punitd
Galaxy Note
After updating to android 11. Battery drains very fast. Usually i charge my mobile after 6-7 hours but now even in idle mode battery is draining very fast... needs charging after every 3-4 hours..
8 REPLIES 8
rahmatalif
Expert Level 3
Galaxy Note
after update, you will be entered recovery mode to wipe chace partition😉, how to enter recovery mode, Your phone just Powerly off, put data cable to PC/Laptop, Push power bottom and volume up with same time, wait to blinked screen after that you got recovery mode, just use volume bottom to chose list and power bottom to agree, then chose wipe chace next to Reboot system now, well done🙂🙏
punitd
Galaxy Note
as soon as i finish wipe cache partition and reboot the phone... after 5 minutes of use it starts getting heated 🤦‍♂️🤦‍♂️
rahmatalif
Expert Level 3
Galaxy Note
idk, its natural, your phone well be adaptions for it, wait be patient😁🙏
punitd
Galaxy Note
phone backside at top near camera temperature reaches 42 deg C. at bottom around 38 Deg C
punitd
Galaxy Note
okay i try this first.. then update...
rahmatalif
Expert Level 3
Galaxy Note
you forget'nt to tap repply bottom😉👇
clownnn
Expert Level 3
Galaxy Note
no matter bang, it is a part of being updated to new software. the phone has been adapting with the current usage. just wait for at least one week then come here to discuss more
Moderator3
Galaxy Note
Hi, you can try to do the troubleshooting solution: wipe cache partition and if its still drain, maybe its because the "adaptation" of the new update, please wait till it become normal. thank you
