BATTERY DRAIN
(Topic created on: 10-12-2019 01:15 PM)
DesmondLum
Galaxy Note
Note 9 seems battery drain like crazy,anyone facing this problem??
27 REPLIES 27
DesmondLum
Galaxy Note
currently using android pie
k31vin8
Galaxy Note
U can restrict those app
Device Care->Battery->Sleeping App
DesmondLum
Galaxy Note
I did,but still the same
haematocrit
Galaxy Note
I can see Brawl Stars. 👀
k31vin8
Galaxy Note
haha but i haven't played for a long time
DesmondLum
Galaxy Note
does Package Disable Pro (Samsung)help?
k31vin8
Galaxy Note
never try that before,I use greenify
FUN2000
Galaxy Note
It helps but you need to know which app you should disable. If you accidentally disable certain services, you phone will have some issues.
DesmondLum
Galaxy Note
it helps alot?
