Battery Heating Issue?
(Topic created on: 04-25-2020 12:00 AM)
Benzo16
Beginner Level 4
Galaxy Note
Is there someone experience the same battery heating issue with your note9 after updating the os?
5 REPLIES 5
PaulN
Galaxy Note
Hear hear! Same experience with my note 9
RJdagz
Galaxy Note
Read this from Samsung's page:
Reasons your phone warms up
• During the initial setup after purchase or when restoring data
• Intensive Camera use
• Using apps that require more power or using apps for extended periods
• While multitasking (or, when running many apps in the background)
• Exposed to Extreme Heat
• Blocked Ventilation
• Poor Signal Strength
• Charging the battery with a damaged USB cable
• Device’s multipurpose jack is damaged or exposed to foreign materials, such as liquid, dust, metal powder, and pencil lead.
Ways to Cool Your Phone and Keep It Efficient
• Keep the device updated with the latest software.
• Remove the phone’s case
• Move it from direct sunlight
• Reduce the display brightness
• Deactivate the Wi-Fi, GPS, and Bluetooth features when not using them.
• Close apps that increase battery consumption or that run in the background when not in use.
• Delete unnecessary files or unused apps.
https://www.samsung.com/ph/support/mobile-devices/my-phone-is-heating-up-is-this-normal/
If the above doesnt work still you can also try soft resetting, last resort is a factory reset
Jani24
Galaxy Note
It's not about the OS but it's more of how you use your phone.
Reesch
Galaxy Note
Yes it might be. 😅
Charlon
Galaxy Note
try to check background processes that could also contribute.
