zaxxon
09-08-2016 05:25 AM in
Galaxy Note
Anyone experiencing issues with keeping a screen protector on an edge phone with a case?
I have a note 7 and the corners of the screen protector keep getting lifted by the case. I have tried different cases with no success.
Anyone have a good (thin) case and screen combo?
7 Comments
Echo1
Expert Level 4
09-08-2016 07:58 AM in
Galaxy Note
I use Spigen on a S7 edge and works well for me no issues at all
AshleyB
09-08-2016 10:15 AM in
Galaxy Note
I don't have a note but I do have the s7 edge and the screen protector never stayed on properly. It would bubble.. I had warranty so they would replace the screen protector with another and same thing again. Finally I just decided to not use a screen protector. I've heard of others also experiencing the same thing.
Dilbert
09-08-2016 12:01 PM in
Galaxy Note
Use Spigen products
zaxxon
09-08-2016 03:38 PM in
Galaxy Note
I am using a spigen case
zaxxon
09-08-2016 03:39 PM in
Galaxy Note
Not sure the screen protector
crugory
09-08-2016 06:07 PM in
Galaxy Note
I'm using a curved tempered glass protector (ishields i think ) with the Samsung "jelly" case for my note 7.. the two are a perfect fit.. with barely a seam between them. all the other cases I tried were a few millimeters to tall and would lift the edges of the protector.
mellerz
09-23-2016 11:12 PM in
Galaxy Note
the edge is tricky when it comes to screen protectors. pretty much either a screen protector or a case.. unless you find one that comes together.
