Note 20 Ultra Battery
(Topic created on: 09-03-2020 05:28 PM)
royps
Galaxy Note
I recently buy a new Note 20 Ultra, however, my battery seems to drain fast. When I sleep at night with all apps and wifi closed, it drains about 20% when I wake up. How long does your Note 20 Ultra battery last?
14 Comments
waaa5
Galaxy Note
Is always display on? Also it could be that your phones AI is calibrating the battery for the first week so its can be normal.
royps
Galaxy Note
Anyway, I have it tested by samsung and said that discharging is abnormal. It also charge longer than expected. I will have my unit replaced.
Francesco64
Beginner Level 3
Galaxy Note
Having a similar experience. Battery percentage drops really fast.
Reesch
Galaxy Note
Just observed it some more time. If you feel like it needs to be replaced then do it. The decision is always up to you. 😉
r2nhel
Galaxy Note
At night my battery drops around 4-6% (airplane mode but wifi is turned on for app updates I leave my phone near me kasi). then usually if my phone is above 90% in the morning, with data on, constant work chat, text, call and socmed, I tend to grab my charger around 2 to 3pm.
AiBun
Galaxy Note
same here
royps
Galaxy Note
Thanks for all the info. My unit has been tested by Samsung and found out that the battery is really defective. Still waiting for the replacement.
jayr007
Galaxy Note
Got my note 20 ultra last week. The battery **bleep** it only last 4-5 hrs when it's on 120hz while 5-6hrs on 60 hz and draining when im in sleep. Should I bring it to the service center? Im really disappointed with this. Thanks for your reply.
royps
Galaxy Note
If you think the draining while you are sleeping is too unusual. have samsung check your phone. mine was replace because upon my own observation, there is a problem with charging the phone, it takes 3 hours to fully charge, overheating and insanely had to charge 3x per day.
When I got my replacement phone, with heavy use, it take 6-8 hours screen time, sometimes less. Note 20 Ultra battery is actually 'rubbish'. That's the sad truth.
