45 watt wall adapter charger
(Topic created on: 04-23-2022 06:49 PM)
Jobeth
Hello po! Could you please help me find a legitimate online store for samsung wall charger. I'm looking for a true rated 45watt wall charger for S22 Ultra. Pa hingi naman ng links of your trusted online store. Thanks in advance.
7 REPLIES 7
butete
able to buy from shopee need also to get different usb cable to maximize 45w20220415_104853_1799_1649990933.jpg20220421_122947_2336_1650515387.jpgScreenshot_20220421-123250_One UI Home.jpg
Jobeth
I tried to search this 45watt charger issue in the other thread and looks like Anker is promising based on the on and off thread reviews. Thanks bro.
butete
yes others gave anker good feedback, lets see, after a year how this 45w power brick performs so far it does the job.
H3ntaiKam3n
If you want 3rd party and truly tested.. you may try what i'm currently using.
Baseus GaN3 Pro 65w.
It already comes with a 100W charging cable. Got it for 1439Php at Shopee, which is alot more cheaper than other brands which doesn't even include a charging cable.
Why i got this? It supports multiple charging protocols, PD 3.0, and PPS.. so i can use it on my mobiles, laptop, and other devices.. its also light and compact with foldable plug..20220428_135507_1918_1651125309.jpg20220428_135752_1922_1651125473.jpg20220428_135724_1921_1651125445.jpg20220428_135658_1920_1651125418.jpg
Jobeth
Hi! Got an Anker Nano II 45watt charger last weekend and I am satisfied with the power output and charging time duration. Thanks for the suggestion.
Gray1995
Hi Jobeth I have original samsung 45 watt wall charger I've used it for my Samsung s20 ultra 5g wanna buy it?
Jobeth
Hi Gray! Got an Anker Nano II 45watt charger last weekend and I am satisfied with the power output and charging time duration. Thanks anyway.
