Battery and Nougat Starter Pack
(Topic created on: 03-21-2017 05:52 PM)
kit71717
Hi guys,
I just upgraded to Nougat and I feel like the battery is draining really fast compared to Marshmallow, I dont know what went wrong since I am using it like usual.
Also, what should I do after updating to Nougat? I restarted the phone, but are there other steps I should take to have a smoother transition from M to N?
9 Comments
Brando
What will really make you have the best transition between marshmallow to Nougat is a factory reset. It can be inconvenient but it can also be worth it.
kit71717
Hey man, is there a way to backup everthing, do the factory reset and recover everything (apps, pictures, documents, files)?
Brando
settings > cloud and accounts > backup and restore
make sure google backup is on and auto restore is on. Then Go to Samsung account backup and make sure everything is on and press backup now
abdul
u can also use samsung smart switch. its easy, simple and works fast
Moderator_
Yup, it's always good to run Smartswitch even if you have files saved in the cloud. (Just in case!) A full backup only takes about 10 minutes. -Nick
kit71717
ok thanks, but does Samsung Back up Photos and Videos too?
Brando
Go into Samsung cloud and make sure gallery is turned on. You should be good to go. I reset many times and did not lose any of my photos from gallery.
kit71717
I dont have gallery though
Brando
What do you use to store your photos?
