05-18-2025 09:57 AM (Last edited 05-18-2025 09:58 AM ) in
Galaxy S- Tags:
- batterydrain
- S25Ultra
05-18-2025 03:22 PM in
Galaxy S- Mark as New
05-18-2025 04:20 PM (Last edited 05-18-2025 05:53 PM ) in
05-29-2025 09:03 AM in
05-19-2025 10:51 AM in
Galaxy SUpdate your apps on the Google Play Store and Galaxy Store
Restart the device
Make sure u have the latest update on everything
System updates and Google Play System Update
Turn on battery protection to 95%
05-20-2025 07:55 AM in
Galaxy SHi LXN,
We understand how frustrating unexpected battery drain can be, and sorry to hear that your'e experiencing this issue after the update.
To help improve battery performance, please try the following:
Please try the recommended Steps:
Review Battery Usage by App: Navigate to Settings > Battery > Usage since last full charge and check for any apps using excessive battery in the background.
Wipe Cache Partition. This can help if any temporary system files are causing conflicts after an update: Power off the device. Press and hold Volume Up + Power until the Samsung logo appears. Use the volume buttons to highlight Wipe cache partition, and confirm with the Power button. Reboot the device.
Safe Mode Test: Boot into Safe Mode (Press and hold Power → Tap and hold Power Off → Select Safe Mode) to see if third-party apps may be contributing to the issue. If battery life improves in Safe Mode, an app may need to be removed or updated.
Submit an Error Report: If the issue continues, please open the Samsung Members app > Support > Send feedback > Error reports > Battery. This allows our development team to analyze your device logs and provide targeted support.
We truly appreciate your patience as we work to ensure the best experience for all Galaxy users. Your feedback is valuable and already helping us improve future updates. Please let us know if the issue persists after trying these steps.
Thank you.
