Highlighted
Why is my battery draining so crazy fast on my S10+ on the January update? Does anyone have any similar problem? Before the update, it was way better, didn't get hot when charging or anything. But now it's really bad. Gets hot and drains faster than usual.
Any help would be great.
Thanks
Geico
3 Comments
Highlighted
Did you tried cache cleaning into recovery mode ?
Highlighted
You could have a bad app or more causing the problem
Boot into recovery and wipe cache
If all else fails backup your data and then reset your phone
Highlighted
I'll do that.
