BATTERY DRAIN - S24 ULTRA
(Topic created on: 03-06-2024 03:32 AM)
DeanRiparip
Hi everyoneee!! I got my S24Ultra last March 1, so when I got it I got it full charged to 100 then after 30 seconds it went down to 99 I called Samsung CS they told me its because the new phone is optimizing, after 5 days from 100 after 4 minutes it goes down to 99 even though i'm not using it.
7 Comments
Lingsan_Kayna
Check background running applicantions..
I also suggest turn on your battery protect
MAAAYMAAAY
Same!!! 😒
DeanRiparip
:( is yours fine now???
MAAAYMAAAY
I usually charge it until 100 on days I need to go out.. unfortunately, no.. I limited the background processes and all.. it gets better when the batt's at around 70-80% tho.. still hope this gets fixed.
DeanRiparip
Is yours fine now?
Check your battery usage and see which apo is fast draining your battery. Also listen to what samsung cs told you. Give your phone a week or two to optimize based on your usage. Dont be paranoid at the moment, just use your phone normally.
SonnyCalooy
Pag gamit na gamit talaga, kaylangan na ng power bank for emergency
