03-03-2023 09:30 AM in
Galaxy S- Mark as New
03-03-2023 09:59 AM (Last edited 03-03-2023 11:59 AM ) in
03-03-2023 10:52 AM in
Galaxy SThe first time you Boot a brand new device, it's also doing a bunch of stuff in the background.. So fully charge it & give it a few days.
It's called "Adaptive Battery" for a reason.
03-03-2023 12:44 PM in
03-04-2023 05:52 AM in
Galaxy SMine did the same thing, but a I'm a few weeks in now and the battery is very good. Just carry on as normal and see what happens.
03-04-2023 08:45 PM in
Galaxy SHi, during the first few days after purchase, you have usually activated many applications and set various features for initial device setting, and the frequency of background operation is optimised at this period.
So, you may feel the battery usage time is shorter compared to when you were using your previous device.
You can optimise your phone using the Device care feature to reduce battery consumption by closing unused apps and controlling abnormal battery usage.
Open Settings, and then select Battery and device care >> Tap Optimize now >> Device care automatically optimises your phone.
The more unused apps there are running in the background, the more power your battery will use. Background usage limits can be set to reduce battery consumption.
Open Settings and then select Battery and device care >> Tap Battery >> Tap Background usage limits >> Set the app you want to control.
