Battery drainage
(Topic created on: 07-07-2024 05:52 AM)
Chiggy
Anyone having issue with battery dropping so fast on s24 ultra? What can be done to fix it?
14 Comments
Members_hK4nbp2
I am having the same similar issue.
Chiggy
Yeah, I have noticed it drains the battery even on screen off.
pchan0
mine's still getting pretty good battery life, can you share your SOT screenshot?
Chiggy
pchan0
what about the part where it shows which apps are using the battery part? 5 hours SOT is pretty average battery but you also top up the battery throughout out the day too.
Chiggy
How about your average use on screen?
pchan0
this is mine, no top ups between full charges. About an hour of SOT with a 10% drain is what I'm getting every day.1720358068407.jpg
Chiggy
Here's the another day of use without charging.1720358107598.jpg1720358107601.jpg
pchan0
Ah, AOD I have that turned off. That drains the battery.
