sonsi
08-29-2022 05:24 AM in
Hi! Any tips on my samsung galaxy 21+ 5G regarding the battery? It seems my battery draining so fast even my unit does have 4,800 mAh. Thanks!
Solved! Go to Solution.
Mak_30
08-29-2022 05:33 AM in
Turn-off mo nlang fast charging mo kasi ako yan naging way ko para mas humaba ang battery hours na pwede ko magamit ang unit
3 Comments
Mak_30
sonsi
08-29-2022 07:42 AM in
S21+ din po unit ninyo?
butete
08-29-2022 06:21 AM in
use 60hz and if you are always on wifi set connection at 2G
