mrabid0001
07-19-2023 10:38 AM in
On July 18 2023 at morning I got software notification and I update software from that time my battery start draining I did apply safe mode even fir 3 hour I did check device care as well Nothing work. Is that a trick from Samsung to the customer's.
2 Comments
Tallman
07-19-2023 12:50 PM in
Try Wipe Cache Partition after updates.
- Power off your phone
- Press and hold vol up and power key until you are in recovery mode
- use vol up and down to navigate
- select Wipe Cache Partition
- press power key to confirm
- click yes
- click reboot system
- click yes
