Resolved! Solved
Battery optimization
(Topic created on: 06-15-2022 12:09 PM)
iFlYSoLo
Are there any apps you would recommend turning off battery optimization? Just a curious question..
Thank you
RedDogRabbit
Find My Mobile, I NEVER want it to be sleeping! lol
Any apps that I want to always be readily available.
VPN if you have it things like that.
10 Comments
RedDogRabbit
iFlYSoLo
Someone woke up lol
RedDogRabbit
He*ck, I'm still sleeping 😴
iFlYSoLo
Lol...
Theblueberry
Just turn battery optimization off. I get way better battery life with that disabled
iFlYSoLo
Oh really..i thought it would be the other way around..
Theblueberry
Yeah you'd think so wouldn't you?
But I just found it doesn't work very well.
I'm not sure if switching off the system wide battery optimization disables it for each app. I'm pretty sure it doesn't, because I still have certain apps I changed the settings for specifically.
But you should definitely turn it off for a few apps you don't want killed randomly. Mine is turned off for things like, VPNs, adguard, syncthing, just apps I generally need to always be running.
iFlYSoLo
Makes sense.. thank you!
iFlYSoLo
Do I need to go in every single app to turn it off?
