Battery Saving Tips
(Topic created on: 07-17-2024 12:09 AM)
RoroNoah
1. Turn Off Google Discover.
 How about you? How do you improve your phone's battery?
5 Comments
Dark mode
60fps
RoroNoah
For those who are using Dev. mode.
RoroNoah
Turn it all off.
RoroNoah
Debloating also helps to improve battery life.
RoroNoah
Set this to Wi-Fi only so as to reduce battery consumption whenever you are using mobile data. It's a long list of apps. I just showed you the difference between the apps that are set to Wi-Fi only and those that are set for both mobile data and Wi-Fi. 
