Battery usage
(Topic created on: 03-27-2022 06:13 AM)
RJr12
I don't know if mabilis ba malowbat or normal lang to sa mga s20 fe sd local variant. I've been using this for a month na pero I bought it as 2nd hand item and 6 months palang to from original purchase galing store. Sa tingin niyo po? Sorry guys bago bago palang ulit na samsung user😄
15 Comments
CrissCross
Baka po nadegrade na ang battery.
Try ninyo pong mag-install ng Accubattery at ipa-scan ng app yung Battery Health. Mababasa niya po yung battery health ng mga Android.
RJr12
Check ko nga po yan. Nacorny han lang ako sa batt nito kasi halos3x ako mag charge sa buong araw kahit normal usage lang.
Matt52Playz
Pretty normal for samsung s20 fe take not that it also have 120hz display and maybe your brightness is high and soo many background apps, s20 fe have this issue since it was realeased soo no suprises some usesrs even getting bellow 3hrs of use even on light use soo yup normal
RJr12
I always close background usage and do clean device. I also set my brightness to 30-40% only even when I'm outside. Can't really tell kung may prob ba batt nito simcenew user lang ako.
Matt52Playz
It might be many people is reporting bad battery life in samsung s20 fe soo yes maybe
RJr12
Ayon lang. Sad to hear this.
TeamGalaxyDD
TechTalker
for mobile data usage, I could say it's normal
RJr12
Maybe all I can do is to accept that's the reality for s20 fe. I thought something is wrong with my phone 😄
