Battery
(Topic created on: 05-18-2024 12:34 AM)
DenzB
Help
Ano possible mang yayari kapag ng BATTERYSTAT RESET ako, hindi na bah ako makakarecieve nf software updates galing k samsung?
Salamat
5 Comments
wandylnn
Performing a batterystat reset should not affect your ability to receive software updates from Samsung. This action typically just resets the battery statistics on your device and shouldn't interfere with the software update process.
Walang kahit anong pag tinker ng settings ang pipigil sa phone na maka receive ng software updates, unless end of software support na.
butete
delay man update, darating at darating din
dulber
Paano ginagawa yang batterystat reset? Standard feature ba sya ng Samsung phone? Anong phone model mo?
DenzB
Samsung s21 FE
