11-26-2022 08:58 AM in
Galaxy S2 Solutions
11-26-2022 09:57 AM in
Galaxy SHi, please try to Reset Bixby and check if the issue is solved.
To reset Bixby, navigate to and open Settings.
Tap Apps, and then swipe to and select Bixby Voice.
Tap Storage, and then tap Clear data.
Tap OK to confirm, but remember, all your previous Bixby data will be reset.
Next, tap Clear cache to completely refresh Bixby.
11-27-2022 10:57 AM in
Galaxy SHi, we are good to hear that your issue has been resolved.
Kindly get back to us if you require any further assistance.
Please take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Accept as Solution" and help others with the same query.
11-26-2022 10:08 AM in
