Camera pro mode not working
(Topic created on: 03-16-2018 04:25 PM)
Shawn1
So i've had my s7 edge for a while now and i don't really use the camera often but i was curious and opened the pro mode on my camera app but it all i get is a black screen but when i switch it back to auto, it works as if nothing was wrong. Please help if anyone knows or has had this happen to them. Thanks36fdd91b-4277-47f6-ae1d-41eba1097334.jpg
12 Comments
SHONG
Raise the exposure. Right now, it is in 1/24000, but try it in auto.
Shawn1
that worked, thanks so much
Shawn1
but also what is the one that i cant change, the +/- one and why cant i change it
SHONG
I don't know what that does, but you can only change it with the exposure set to auto
PixelCheese
Set the shutter speed to auto then you will be able to change the exposure settings (the +/- button).
great tip @SHONG!!
Moderator_
Hey @SHONG! Thanks a lot for your answer!
- Wonchul
Shanisse
How do u set the camera work. as I'm not sure how to get the best picture
Shanisse
What was the answered.
