11-08-2024 03:53 PM in
Galaxy S- Mark as New
11-11-2024 09:29 AM in
Galaxy SHi bigbeardy71,
Can you please tell us the model of your device and the model of the earbuds? Please try the below steps which may help to solve the issue.
Please check the Bluetooth volume independently from the phone's main volume. Sometimes, Bluetooth devices have their own separate volume control.
Also, ensure that the media volume on your phone is turned up, not just the ringer volume.
You can also try forgetting the earbuds from your phone and then reconnecting them.
Go to Settings > Bluetooth, tap on the connected earbuds, and choose Forget. Then, re-pair them.
If possible, please try connecting your earbuds to another Bluetooth device (like another phone or tablet) to see if the issue persists. This can help you determine if the problem lies with your earbuds or your phone.
Thank you.
11-12-2024 07:20 AM in
Galaxy SI will try to follow the steps that you've suggested and get back to you with the result.
Thank you kindly.
11-27-2024 04:29 PM (Last edited 11-27-2024 04:31 PM ) in
Galaxy SI'd tried a couple of things, such as making sure my buds were fully charged. The next thing was to press down on them while in their case. Whatever I did seemed to work, but sadly, only the right one is still working, and it sounds good. I guess just playing around with it seemed to do the trick.
I believe that I'll be getting a new pair for Christmas 🎄 ☺️.
Thanks for your suggestions and happy holidays.
