Fast wireless charging
(Topic created on: 04-19-2024 07:46 AM)
dulber
Interesting. The charger couldn't quick charge an iPhone 13 but the S24u recognizes and effects a quick charge.
12 Comments
Dabomb
Hello. What brand do you use?
dulber
I tried with this https://ph.shp.ee/zCZmrdS. They all heat up but this heats less than another brand I had waaaay before that the phone stops charging. Sharge may be the way to go if you fancy wireless. Or Anker https://ph.shp.ee/MwVabGk. I'm still configuring a car wireless charger but might go to ESR Cryo
Dabomb
Thank you
Dabomb
Hello again. I checked the links you've sent. I can see that those are wireless powerbanks. Do you have/know any other fast wireless chargers that can be plugged in the outlet?
I'm currently using this nillkin fast wireless charger for my lg and samsung, but it is not supported by my s23U. The good thing about this charger is that it doesn't heat up at all because it has a fan inside.20240606_141855_1000005562_1717654738.jpg
dulber
Oh, sorry. This post was for wireless fast charging. I also have AC corded chargers from Choetech 40W, Baseus for 65W and uGreen for 100W. Let me grab the shop links. Baseus https://ph.shp.ee/E9JsNEH I suggest searching their store so you can get a better AC outlet port. This is specifically for my wifes monitor.
Dabomb
Got it. But I'm actually looking for a fast wireless charger that isn't a powerbank to be used in my office 😄
dulber
Dabomb
Gotcha, but a bit expensive, haha
dulber
Unfortunately, I'm monitoring for price movements. Looking to snag the car charger but still contemplating. I work from home and can charge from many wired sources. So no immediate need for wireless.
