galaxy s20 plus fast battery drop after full charge
(Topic created on: 06-09-2020 07:20 PM)
hmocampo06
hi, ung s20 plus ko after fully charge ng 100% kahit naka off na wifi after 5-10 minutes na hind ko ginagamit nag dadrop ung battery nya agad to 99 - 97%. Im not sure if defective ba ung unit ko or what.  kakabili ko palang nito nung May 29. Any same experience po? Salamat
11 Comments
embs
parepareho tayo nang issue sa phone😭
sana naman maayos pa ni samsung toh..
Guys normal Poh Yun kahit walang background Apps Power off lang ang sulution
long press the power button press power off
Charlon
for me normal naman yung ganyan lalo na may mga bacground apps na gumagana.
matagal nang issue yan sa samsung fast drop from 100 to 99 kahit kakatanggal mo lang ng charger at d mo pa ginagamit
Reesch
That's what I have observed whenever the fast charging was on while using the phone. It fully charged so fast and dropped its juice in just a sec. That's normal though. 😊
VoxLament
from the first galaxy S unit to s20 ultra eto na problema.. normal na ata to sa mga samsung phones! comapred to other phones like huawei (P Series and Mate series) mas matagal nga battery life nila maybe because of the screen used sa mga phones! oh well, okay na din dahil mabilis din mag charge and tumatagal naman sya maghapon! di naman masyadong lumalabas ngayong may ECQ/GCQ kaya okay lang! hehehe
Embenitez
Hi. Pwede nyo po itry mag install ng Package Disabler. Tas disable nyo po yung mga facebook services, facebook installer, facebook plugin. Yun po yung nagddrain nang sobra sa batt pag idle. Just don't disable the Facebook app itself then you're good. Walang mawawala na data or anything. The things that I mentioned are just like bloatwares na kumukuha ng data mo to show you ads based on how you use your phone (like checking things on Lazada or Shopee kaya bigla na lang lalabas sa fb mo yung item as ads haha). Dati full batt ako sa gabi tas pagkagising I'll only have 86%. Nung nag package disabler ako, I wake up at 96%. 8 hrs duration po na idle yan. Hope this helps!
qncylane
Beginner Level 4
Hello po ano exactly yung app? Yung kay samsung mismo na Php 145?
Embenitez
Yes po yung Package Disabler Pro (Samsung) po yung sakin. Sadly may bayad po siya. I took the risk po and bought it and happy naman po ako since nabawasan talaga yung drain. If balak niyo po bilhin din, I suggest basa po muna kayo sa net about it and alin mga suggested na i-disable na apps. Personally, dinisable ko mga bloatwares ng Samsung and pati na rin yung Bixby voice ata since di ko siya nagagamit and lagi ata syang nakastandby so nagddrain din? And isa pa sa dinisable ko is yung digital wellbeing. May nabasa ako sa net na isa yun sa nakakadrain eh. So yun okay naman po performance ng batt ko now ☺️
