Help for Samsung Volume limit PIN
(Topic created on: 07-22-2020 01:48 AM)
Cibi
I did a pin for my volume limit and I forgot that, is there any chance to get it back? Please help
13 REPLIES 13
Cibi
it's okay. I fixed it by reset my settings.
Never do a pin on volume limit, there is no recover on that pin.
Not applicable
did any one know how to reset the media volume
Pchase
Beginner Level 3
How do you reset your pin,because I forgot my pin and I'm really mad
DDxD
How do you reset your settings
Kinsley
Hi Cibi,
Glad to know that your query got resolved.
Cibi
yeah with sacrificing my saved setting
Kinsley
Below are the steps to set a volume limit pin for those who don't know how to set it.
Open Settings >> Sounds and vibration >> Volume >> click on three dots top right corner >>  media volume limit >> make sure it is switch on >> Set volume limit pin >> put Pin and confirm it.
Note: you can not increase the volume until you enter the correct password.
I hope it will help some people to set a volume limit pin.
DDxD
I never put in a pin but its still asking for one how am i supposed to take it off with no pin this feature is so annoying and unnecessary
Sanmintun
Please help me! I forgot my media volume limit pin? How to solve it?
