06-11-2020 09:37 AM in
Galaxy S- Mark as New
06-11-2020 11:14 AM in
Galaxy SHI TheMacine,
Please make sure that you have a good internet connection as it slows down the upload process. I also suggest you to try uploading videos of different sizes and also try disabling the VPN and use a different wifi network.
06-11-2020 12:03 PM in
06-12-2020 09:53 AM in
Galaxy SThanks Tallman and lustik.
Hi TheMacine, The maximum file size allowed for all media (photos, videos or voice messages) to be sent or forwarded through WhatsApp is 16 MB on all platforms. Please try with media files with less than 16 MB and check if you are facing the same issue. If you are facing issues with a particular video, then please check if the file format is supported by Whatsapp.
06-12-2020 03:03 PM in
06-11-2020 12:44 PM in
06-11-2020 12:59 PM in
06-11-2020 01:15 PM in
Galaxy SOpen Settings → Apps→ Whatsapp → Storage
Click clear data and clear cache
Try Whatapp again and see if the problem still exist.
06-12-2020 12:29 AM in
06-11-2020 07:56 PM in
