Naksu07
09-01-2023 04:32 PM in
I have two issues:
1. After an update, my phone seemed to have lost function of its dial pad when on a call, dealing with automated phone options. It doesn't register my entries; so,
2. I needed to call the #Galaxy but it won't connect.
Anyone knows what I can do?
Solved! Go to Solution.
butete
09-01-2023 05:07 PM in
5 Comments
butete
wipe cache partion should help
Naksu07
09-01-2023 05:14 PM in
I couldn't seem to find Cache in the settings. Would you know where it is?
butete
09-01-2023 05:38 PM in
turn off device, connect device on a pc power on + volume key then it will enter recovery mode
on the menu you will see
Naksu07
09-01-2023 05:49 PM in
Thanks a ton! I found the cache and cleared it. Now works!
butete
09-01-2023 06:16 PM in
hooray glad it did the job reminder every update you need to wipe cache
