Help
(Topic created on: 04-10-2023 07:20 AM)
DenzB
Good pm
Puwede bah ako mag delete ng data safe bah kasi medyo nakakaramdam nq ng mabagal na phone ko 11 months old na siya malapit na mg 1 year old Samsung S21 Fe...
Salamat
johngear
Pwede. Just make sure na naka back up ang mga important files, docs and accounts mo.
9 Comments
johngear
DenzB
Mismo sa folder ng android mag delete ako safe bah baka hindi nq maka tanggap ng updates kapag ng delete akl mismo sa folder ng android
johngear
DenzB
Yap tama po kayo iconnect ko sa laptop ko den mg dedelete ako ng mga folder doon, safe kaya baka hindi nq maka recieve ng software update kapag ng delete ako doon
johngear
Safe naman. Makakareceive kapa rin na software update kasi di ka naman magmomodify ng system
johngear
Oks naman magdelete kaso mangyayari nyan apps data and account mo marereset.
TeamGalaxyRene
Hello DenzB,
Thanks for reaching out to us here in order to find out whether it is safe to do so by deleting data directly from your Samsung Galaxy S21 FE Android folder.
Samsung Galaxy smartphones come with a large amount of internal storage capacity for you to save your pictures, videos, games, and apps. However, you may still need to free up some storage space from time to time if you want to install large apps or save longer videos.
In order to free up some needed storage space, I've listed them down for you.
1) Check how much storage space you have.
2) Empty the recycling bin.
3) Uninstall unused apps.
4) Delete duplicate files.
5) Delete large files.
6) Move files to an SD card.
7) Clear Cache Partition.
Step 1. Turn off your phone.
Step 2. Plug in the USB cable via PC or Type-C earphones (in case its USB-C to USB-C).
Step 3. Then press and hold Power and Volume up buttons.
Step 4. Release the power button. When the recovery screen shows up, release the volume up button.
Step 5. Navigate to and select Wipe cache partition (Volume up and down is for highlighting options and power is to select).
Step 6. Navigate to and select Yes.
Step 7. Press the power button to select Reboot system now.
For more assistance and guidance, you may contact us via our online Samsung Customer Care support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
Or our Samsung Customer Care direct hotline numbers below.
#GALAXY or #425299 [Mobile Phones & Tablets]
Available 24/7
1-800-10-7267864 [All Product, Toll Free, PLDT]
1-800-8-7267864 [All Product, Toll Free, Globe]
842 221 11 [All Product, Landline]
Daily (8:00am to 8:00pm)
Stay safe and have a nice day ahead! Thanks for contacting Samsung.
safe mag delete
DenzB
Salamat po medyo okie na ng clear cache nq sa telegram medyo madami movie doon hwhwhw, hindi bah maapectohan baka hindi nq maka recieve ng software update po eh kapag ng clear cache ako
