Help
(Topic created on: 11-23-2023 09:44 PM)
Neeks14
Quick question. I have an S23 Ultra and for some reason, my Samsung calendar widget icon is not displaying the date in real time. For some reason, it is stuck on 28 and does not change when the date in real time changes. It used to, but not anymore. I've compared my phone to a few of my other friends who also have a Samsung phone, and their calendar widget icon changes in real time. Any help you can give me so I can have my widget on the home screen display the date in real time again? Thanks in advance!
8 REPLIES 8
You can try clear the Calendar app cache. Settings -> Apps -> Calendar -> Clear cache
Neeks14
Thank you for the tip Tallman, but clearing the cache didn't work. You almost had the correct path. It's
Settings-> Apps-> Calendar-> Storage-> Clear Cache
Helenna
Hi, just to confirm after performing the above steps are you still facing the problem ?
Neeks14
I am still facing the problem
Check if you have any app updates in the Galaxy store.
Open Galaxy store, menu, then click updates. Update all the apps.
Are you using a different theme?
Neeks14
No available updates. Everything's up to date. What do you mean by different theme? Sorry.
Themes like different icons or are you using the stock icons?
Neeks14
Stock icons
