Help
(Topic created on: 03-16-2020 02:48 PM)
callie2017
Hello
Is there a way to recover text messages back someone deleted all text messages that were not to be deleted
22 REPLIES 22
JohnH
Text messages can be backed up to Samsung cloud, and for some reason my phone seems to do that automatically so maybe yours does too. Go to "accounts and backup" in your settings, press "Samsung cloud", and then it should say when your last backup was.
If it was recent, you can restore your chats by hitting restore and selecting chat history.
callie2017
that didn't work
Jeremie
@callie2017,
As suggested by @JohnH, If you had backed up the Messages app using the Samsung cloud, then you would have been able to restore the deleted messages from it.
callie2017
didn't work
GNote10plus
Which phone and Android version are you using?
callie2017
A50 Android 9
JohnH
When was your last backup? Were there any error messages? If you haven't backed up your phone in a while then there's nothing we can do.
callie2017
it said it was backed up on the 2020, 03,16 at 1:12 am
GNote10plus
Hmm...were the messages deleted before the backup or after?
