How to Fix Galaxy S21/S21+/S21 5G Ultra Battery Drain Issue
(Topic created on: 06-17-2021 09:50 PM)
RjKing
Adjust the refresh rate
The Galaxy S21 series supports up to 120Hz display which makes your display smooth but it can also quickly drain the battery faster because of its high screen refresh rate. The standard refresh rate is more than enough for most users and won’t have any noticeable difference in the experience between the two.
Here’s how to change the refresh rate:
  • Open Settings
  • Tap on Display
  • Tap on Motion smoothness
  • Choose Standard refresh rate and click Apply to confirm the change
2 Comments
MangoTango
Expert Level 3
Thanks for sharing
RjKing
WC
