Xtance
Tips on how to get native bluetooth quality audio in your Smartphone!
Tested in Samsung S20 Ultra.   Tested with Samsung Earbuds Pro.
1) First, listen to any music using your headphones/earbuds you usually listen with all enhancement OFF!
2) Then stopped playing.
3) Go Settings -> Galaxy Wearable Apps -> Change System settings -> NOT Allowed          <- set it to Not Allowed!
4) Go back and listen.
5) if it is 'Not Allowed', then you are already on native.  Try turning "Allowing it" on to hear the sheet differences that Samsung provided.
MangoTango
Expert Level 3
Thanks for sharing
