Inconsistent battery
(Topic created on: 03-30-2023 09:12 PM)
Floppydisk1
I had my S23 plus for almost a month now and the battery has been so inconsistent its annoying like my z flip 3 battery sucked but it was always the same i always knew what i would get now with this phone the battery is either great or just enough.
Right now 1% gave me 15 mintues of youtube which it great. But 4 more mintues after and a lost another 2 more. Where did the battery go. Im doing this samething. Everyday i do the samething. The battery can give me 6-8 Hours of sot which is good. But it should always give me 8 Hours im not a heavy user. I have done every update and every battery saving tip possible. But i just cant get it to act right.
Another then the battery the phone is fantastic. But i want it for the long run and im if the battery is inconsistent now it's going to be even later.
2 REPLIES 2
Helenna
Hi, we are sorry to hear the battery issue on your S23 plus.
We appreciate your efforts in trying all the possible ways to get the issue resolved.
Unfortunately, factory reset might be the last option to fix the problem. Please perform back up and factory reset by following the steps in the given links.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-back-up-and-restore-data/
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
Floppydisk1
No
