Issues with battery on S24 Ultra!
(Topic created on: 04-07-2024 08:30 AM)
Juppreet
Hello guys, Compared to S23U, my S24 U's battery drains faster. I used my phone for 20-25 mins and the battery dropped from 78% to 70%. I have used the maximum option for battery protection which charges my phone tp 80% and stops. I am also attaching the screenshot of my lastest battery stats. I am getting screen on time for hardly just 2-3 hours. Is everyone getting this kind of battery life or is there any issue withe my phone's battery? Are there any settings that i should use or any apps that i should delete? Please help. Thanks in advance.
3 REPLIES 3
Helenna
Hi, that's sad to see that your Galaxy S24 Ultra battery is draining fast.
Please visit the link given below and check if it helps to solve the battery draining issue on your device.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-get-the-most-out-of-your-battery/
GG2
Expert Level 3
I'm experiencing quite the opposite. My S24U'S battery is significantly better than my S23U especially since the last update.
jamesy
I have the s24 ultra. Its been YouTube thats been the culprit for me 1712525007758.jpg
