07-24-2020 06:16 AM in
Galaxy SThe Galaxy S10 Lite successor will be available in a wide range of exciting color options.
- A new leak has revealed the battery capacity of the rumored Galaxy S20 Fan Edition.
- The Galaxy S20 Fan Edition is tipped to have an identical 4,500mAh battery as the Galaxy S20+.
- In Europe, the phone will reportedly be available in four color options – Green, Red, White, and Orange.
Samsung is rumored to be working on a more affordable version of the Galaxy S20, which will offer nearly all its premium features at a significantly lower price point. While the phone's design currently remains a mystery, a new report from GalaxyClub has shed more light on some of the key specs of the Galaxy S20 "Fan Edition."
According to the report, the Galaxy S20 Fan Edition will come equipped with a 4,370mAh battery, which is identical to the minimum rated capacity of the batteries inside the Galaxy S20+ and the Galaxy S10 Lite. This means that the Galaxy S20 Fan Edition will have the same 4,500mAh typical battery capacity as its predecessor.
The report also claims that the Galaxy S20 Fan Edition will be available in four color options in Europe: White, Red, Orange, and Green. As suggested by a recent leak, the phone will sport a triple-camera setup on the back, featuring a 12MP main sensor, a 12MP ultra-wide lens, and an 8MP telephoto lens with 3x optical zoom.
The Galaxy S20 Fan Edition is expected to be quite impressive in the performance and display departments as well. It is rumored to be powered by the same Snapdragon 865 chipset as the Galaxy S20 series phones, although it may only come equipped with 6GB of RAM. The S10 Lite successor is also tipped to have a Full HD+ Infinity-O display with a 120Hz refresh rate.
07-24-2020 11:24 AM in
Galaxy S- Mark as New
07-24-2020 03:55 PM in
Galaxy SFans Edition does sound better and doesn't make the phone sound cheap I suppose.
