Life:Weak on battery
(Topic created on: 06-05-2024 03:05 PM)
Berts
Good morning po, ano pong indication kapag "weak" ang battery?
Ang alam ko lang po is good, normal, at bad.
Pero sakin weak anf naka-indicate sa diagnostic ng samsung members
2 Comments
jamesrred
A "weak" battery indicates that your battery has degraded over time. It is not charging to its full capacity like it did before, and a replacement should be done as soon as possible. You can continue using it, but expect shorter screen on time and charging sessions more often.
It's best to have your device checked and repaired at a service center for quality repair and peace of mind. For your convenience, you may refer to the following link for further assistance:
https://www.samsung.com/ph/support/service-center/
TeamGalaxyDD
Hey Berts!
To add to jamesrred's reply - weak batteries may also mean that a battery's health is compromised - e.g. there's bloating, discharging, etc. It's usually recommended to get your battery replaced as soon as you see this warning. Please head over to a Samsung Service Center near you for a free diagnosis, so you can get a cost estimate on how much a battery replacement will set you back.
