My phone charging says USB connected, and it charges slowly.
(Topic created on: 05-10-2024 01:50 PM)
EC1
So, my charging cable isn't working well. I plugged in the charging cable, and it's charging, but the time is saying 5 h 36 m until fully charged. What could that be?
4 Comments
AWHOOHSTYLE
Are u using rite charging brick for phone
Ray1
Likely the cable so try a different one and if not the cable try a different charging block
Da_JoJo
Either the cable or the power adapter doesn't support PD charging.
Helenna
Hi Da_JoJo, try charging with another different compatible cable.
It is always recommended to use the charger that came in the box or an official Samsung replacement as these have been specially made for your device.
