One UI 4 Battery Drain
(Topic created on: 11-23-2021 09:23 AM)
toash
I've noticed ever since the update my battery just doesn't last as long. I get 4 hours ish of SOT (@36% from 100%). I'm on the S21 256gb. Adaptive refresh rate is on and most apps are on deep sleep. Any ideas or anyone else going through this too?
10 Comments
Reshsu
Same to my s21ultra
GameSky
s21+ user...same case here..
vyan1105
I guess u might try safe mode, if under safe mode ur battery still drain fast .. i guess is hardware issues. Better make appointment visit svc, they might check details for u.
toash
Nah that's not logical cuz then the phone becomes 3ssentially unusable mah... How to get sot of more than 5 hours... And I just got my motherboard changed a month back ... It failed for no reason, luckily on warranty .... And it was fine B4 the update
vyan1105
Then i guess is the software issue 🥺
drpult
Try setting ur phone to dark theme, reduced background activity of apps, optimise your battery (under device care) and reduce performance to maybe high?
toash
As I mentioned I already did all that... And it was fine in one ui 3... Dark mode dark wallpaper adaptive refresh and almost all apps are in deep sleep...
niams1u
Beginner Level 3
me too, i use accubattery apps to monitor
background usage is craaazy
ui 3  0.4-0.7%/Hour
ui 4  1-2%/Hour
toash
